I am trying to pick up GC as I need a certain task done on the project I am working on.
I am using MicroStation and ProConcrete to model a concrete structure and reinforcement bars. Since ProConcrete requires "guidelines" as source of reinforcement geometry, it means that the more complex the concrete geometry is, the more complex the guidelines are and therefore I am looking at using GC to drive the creation of the guidelines that would need to be based on pre-modeled solid geometry in ProConcrete. I hope I am describing this enough.
I have GC installed on my laptop now and I went through the quick start guide to know the basics. I will look for more learning information on the internet.
There are a ew questions I have:
1. How does my Proconcrete model link to GC? Do I have to reference my solid model from ProConcrete to GC and then make GC pickup the solid geometry?
2. How can I link the generated guidelines in GC back to ProConcrete?
3. If the ProConcrete solid geometry changes, how can I translate that change to GC and make it generate a new set of guideleines?
Thanks in advance.
Ken Roxas
I noticed that the Help file that comes with the GC install does not have a list of techniques for each node type and their explanation.
Having a Help file for this will be very helpful to learn the software as it will tell us which technique we need for certain situations.
Answer Verified By: Ken Roxas
