GC scripting table inside table
Hi, is it possible to clone table (dict) variable in GC scripting or have table inside table data structure? Thanks n advance!
Peter
  • Hi Peter,
    It looks like I need to add a 'Clone()' method to tables. But, in the meantime, this script function will do it:
    table CloneTable(table tbl)
        table result = {};
        foreach (item in tbl)
            result.Add(item.Key, item.Value);
        return result;
    Yes. The keys and values within a table can be of any type you wish, including other tables.
    HTH
    Jeff
