I have 3 points which I used 1 Curve and 2 Lines using these points. I thought it would be a closed object but when I try to make a solid using revolve or any other function my error says Its not "Periodically Closed." Is there a function or code available to allow multiple Curves/Lines/PolyLines/etc which are connected to each other into a closed object and define them as Periodically Closed?
Hi David,
Yes, there is: Curve.CompositeCurves will collect the lines and curve to one "composite" curve. This works best if the curves are oriented in a consistent way.
HTH,
Volker
