Hello good GC Community
I've been having the greates time playing with GC this days, but I have a minor question that needs to be answered, so I can continue enjoying this fine tool.
Can anyone explain to me what kind of Input do I need in the "Polygon" Node using the "Offset" Technique??
I'm having a hard time with the "Offset Point" Input, the reason being that when I connect the first Polygon and the remaining nodes, I get an error that I don't understand.
Here is a Screenshot
Best Regards
Rafael
Hi Rafael,
Could you please provide two more pieces of information/data?
(1) when you mouse-over on the error badge, what is the message in it (screenshot of just that fly-over info is OK)?
(2) do you mind providing the script, so that we can check the exact case of what is happening?
Thank you,
Volker
Hello Volker,
Thank you for your help.
I solved the issue by just erasing and creating the solid with another method, but I rewinded the transaction so you can see the code.
transaction 1 modelChange 'Add baseCS, Base_point1, Base_point2, Base_point3, Base_point4, Base_polygon1, Base_solid1'{ node User.Objects.baseCS Bentley.GC.NodeTypes.CoordinateSystem { Technique = 'AtModelOrigin'; DGNModelName = 'Design Model'; SymbolSize = 1; GraphLocation = <auto> {40.0, 40.0}; } node User.Objects.Base_point1 Bentley.GC.NodeTypes.Point { Technique = 'ByCartesianCoordinates'; CoordinateSystem = baseCS; XTranslation = <free> 1553.5518115263; YTranslation = <free> 0.0; ZTranslation = <free> 0.0; GraphLocation = <auto> {314.0, 40.0}; } node User.Objects.Base_point2 Bentley.GC.NodeTypes.Point { Technique = 'ByCartesianCoordinates'; CoordinateSystem = baseCS; XTranslation = <free> 4057.36171942019; YTranslation = <free> 0.0; ZTranslation = <free> 0.0; GraphLocation = {319.0, 235.87}; } node User.Objects.Base_point3 Bentley.GC.NodeTypes.Point { Technique = 'ByCartesianCoordinates'; CoordinateSystem = baseCS; XTranslation = <free> 4057.36171942019; YTranslation = <free> 2153.93488478553; ZTranslation = <free> 0.0; GraphLocation = <auto> {314.0, 431.74}; } node User.Objects.Base_point4 Bentley.GC.NodeTypes.Point { Technique = 'ByCartesianCoordinates'; CoordinateSystem = baseCS; XTranslation = <free> 1593.7593787716; YTranslation = <free> 2153.93488478553; ZTranslation = <free> 0.0; GraphLocation = <auto> {314.0, 627.61}; } node User.Objects.Base_polygon1 Bentley.GC.NodeTypes.Polygon { Technique = 'ByVertices'; VertexPoints = {Base_point1, Base_point2, Base_point3, Base_point4}; GraphLocation = {546.585, 44.968, 0.0, 115.59}; } node User.Objects.Base_solid1 Bentley.GC.NodeTypes.Solid { Technique = 'OffsetFromClosedCurve'; ClosedCurveToOffset = Base_polygon1; GraphLocation = {820.194, 44.539, 0.0, 142.443}; }}
transaction 2 modelChange 'Add Espesor_MDF; change Base_solid1'{ node User.Objects.Espesor_MDF Bentley.GC.NodeTypes.Slider { Technique = 'Default'; Value = 10.0; GraphLocation = {549.168, -120.289}; } node User.Objects.Base_solid1 Bentley.GC.NodeTypes.Solid { Technique = 'OffsetFromClosedCurve'; OffsetAboveCurve = Espesor_MDF; OffsetBelowCurve = 0; }}
transaction 3 modelChange 'Change Base_point4, Espesor_MDF'{ node User.Objects.Base_point4 Bentley.GC.NodeTypes.Point { Technique = 'ByCartesianCoordinates'; XTranslation = <free> 1600.0; } node User.Objects.Espesor_MDF Bentley.GC.NodeTypes.Slider { Technique = 'Default'; Value = 1.96; GraphLocation = {549.168, -104.289}; }}
transaction 4 modelChange 'Add coordinateSystem1; change baseCS, Base_point1, Base_point2, Base_point3, Base_point4, Espesor_MDF, Base_solid1'{ node User.Objects.baseCS Bentley.GC.NodeTypes.CoordinateSystem { Visibility = NodeVisibility.Hidden; } node User.Objects.Base_point1 Bentley.GC.NodeTypes.Point { Technique = 'ByCartesianCoordinates'; XTranslation = <free> 0.0; Visibility = NodeVisibility.Hidden; } node User.Objects.Base_point2 Bentley.GC.NodeTypes.Point { Technique = 'ByCartesianCoordinates'; XTranslation = <free> 500.0; Visibility = NodeVisibility.Hidden; } node User.Objects.Base_point3 Bentley.GC.NodeTypes.Point { Technique = 'ByCartesianCoordinates'; XTranslation = <free> 500.0; YTranslation = <free> 400.0; Visibility = NodeVisibility.Hidden; } node User.Objects.Base_point4 Bentley.GC.NodeTypes.Point { Technique = 'ByCartesianCoordinates'; XTranslation = <free> 0.0; YTranslation = <free> 400.0; Visibility = NodeVisibility.Hidden; } node User.Objects.Espesor_MDF Bentley.GC.NodeTypes.Slider { Technique = 'Default'; Value = 10.0; GraphLocation = {548.335, 168.211, 0.0, 141.237}; } node User.Objects.Base_solid1 Bentley.GC.NodeTypes.Solid { GraphLocation = {839.361, 42.872, 0.0, 142.443}; } node User.Objects.coordinateSystem1 Bentley.GC.NodeTypes.CoordinateSystem { Technique = 'FromPolygonVertices'; GraphLocation = {1203.681, 83.172}; }}
transaction 5 modelChange 'Add direction1, polygon2'{ node User.Objects.polygon2 Bentley.GC.NodeTypes.Polygon { Technique = 'Offset'; PolygonToOffset = Base_polygon1; OffsetMethod = OffsetMethod.ByDistance; OffsetPoint = ; OffsetDistance = Espesor_MDF; GraphLocation = {945.081, 208.372, 174.0, 0.0}; } node User.Objects.direction1 Bentley.GC.NodeTypes.Direction { Technique = 'ByOriginDirectionPoint'; GraphLocation = {668.226, 409.679}; }}
transaction 6 modelChange 'Add Perforacion_point5; change coordinateSystem1, direction1, polygon2, Espesor_MDF'{ node User.Objects.Espesor_MDF Bentley.GC.NodeTypes.Slider { GraphLocation = {552.335, 175.211, 0.0, 141.237}; } node User.Objects.coordinateSystem1 Bentley.GC.NodeTypes.CoordinateSystem { GraphLocation = {1087.481, 340.772, 0.0, 115.59}; } node User.Objects.polygon2 Bentley.GC.NodeTypes.Polygon { GraphLocation = {837.081, 222.372, 174.0, 0.0}; } node User.Objects.direction1 Bentley.GC.NodeTypes.Direction { Technique = 'ByOriginDirectionPoint'; Origin = baseCS; DirectionPoint = baseCS.ZDirection; GraphLocation = {595.946, 442.519, 174.0, 0.0}; } node User.Objects.Perforacion_point5 Bentley.GC.NodeTypes.Point { Technique = 'AtIntersection'; GraphLocation = {1048.896, 113.488, 0.0, 155.87}; }}
Thank you, Rafael.
It is great to hear that you found a work around. This is clearly a sign of your increasing skills with and knowledge about GenerativeComponents.
Of course, I have filed a defect about Polygon.Offset with OffsetMethod.ByDistance. Thank you for pointing to this problem!
Thank you Volker for your support and good words.
I've been enjoying learning GC and is very fullfilling to be able to understand it a little more,and I hope some day I can become a true GC Master.
Thank you again for pointing out this defect. It has been fixed for GC CONNECT Edition Update 2.
Answer Verified By: Rafael Bombardiere Carvajal
