Hi All,
We are currently investigating placing an image on an acoustic panel. We were intending to use 7 different hole diameters to create the pattern.
We have broken the image down to a simple grey tonal range and now would like to draw a grid and in each grid box analysis what colour is dominate then place a circle at the centre of the grid box.
Do you think this is something we can use GC for?
Wayne
Hi Wayne,
Yes, there is an add-in that is built based on the sample project which is available for extending GenerativeComponents: https://communities.bentley.com/products/products_generativecomponents/w/generative_components_community_wiki/6148/image-uvsampler.
This will need to be built for specific versions of GenerativeComponents. I'll see whether I can update the C# project for CONNECT Edition and then make it available as an addition to that same Wiki post.
Volker
Answer Verified By: Wayne Dickerson
Thank Volker,
That looks great.
Let me know if you get a chance to update the project files..
thanks
hi guys, it is little bit older picture of my logo 50x50px which was made in GC SS6 by image uv sampler year ago
I think your "7 holes picture problem" could not be problem at all just to set up right parametres from picture
if you want you can send to me a picture to brainstorm about
have a nice day
karol
The ImageSampler Add-in is now available for the released CONNECT Editions of AECOsim Building Designer with GenerativeComponents:
https://communities.bentley.com/products/products_generativecomponents/w/generative_components_community_wiki/37131/imagesampler-add-in
