I am trying to create a solid object with SweepProfileAlongPath function.
I've created a polygon from 4 points but it is not accepted as an input for solid node.
Do you know what is the requirement of ClosedCurve ? How can i create a closed curve in GC ?
- Polygon node with ByVertices function is not working
- Curve with PointSet function -makePeriodic(closes the curve) On is not working
BR
EG
Hello Emre,
Polygon.ByVertices is acceptable as ClosedCurve input for Solid.SweepProfileAlongPath. In GenerativeComponents, there are currently a few caveats which are not obvious: the Polygon needs to be planar, and the path curve needs to start at the polygon, easiest if the starting point of the path is one of the polygon vertices, but that is not a requirement.
HTH,
Volker
Answer Verified By: Emre GECKIN
Hello Volker,
Thank you man!
BR,EG
