Hi All,
I am working on Bentley Generative Components Connect Edition V 10.00.00.14: When looking through the GCScript Programming section of the help file I noticed there were a few issues with the script that should be corrected in order to get it working correctly.
Under GCScript Programming -> GCScript Language -> Scripting Examples -> Different types of geometric scripts in GenerativeComponents:
Hopefully this helps someone, it might be confusing for someone new to scripting to work out what it is they are doing wrong when the help file is actually incorrect!
Cheers,
Ed
Ed,
Thank you for pointing this out. This has been corrected in AECOsim Building Designer CONNECT Edition Update 1 (v.10.01.00.36).
Volker
Answer Verified By: Edward Ashbolt
Good to hear thanks Volker
