Extrude profile along B-spline curve
Hi All,
Just wondering if someone could help me; is there a way to extrude a profile along a 3-dimensional b-spline curve, without the profile rotating as it moves further along the path? For example, if I extrude a line that is perpendicular to a b-spline curve, and the start and end points share the same Z value, part way along the extrusion, (measuring perpendicular on the resultant b-spline surface) the start and end points differ in Z value, due to the sweeping 'rotation' of the b-spline path since the bspline is curving in both horizontal and vertical planes. Below is an example of the result:
Is there a function that would essentially lock the rotation of the profile as it is extruded along? I was thinking of using 2 'rails' for my swept section, however it is difficult to offset the original b-spline when controlled by poles instead of through points. I may need to resort to recreating the b-spline through control points and see if that yields better results but was hoping there might be a neater solution!
Thanks in advance,
Edward
