maybe something for a function (by Volker Mueller...)
otherwise I would do it about the same way. Maybe you could remove some nodes for widthTotal and lenghtTotal to slim it a bit down.
Ingo
Thinking about this for a while I would prefer using an Excel sheet for the definition of the grid distances.
This allows different grid spacing (as frequently happening) on both axes without hassle.
Hey Ingo,
thank you for your help.
I think your model Looks very nice and I like the Connection to Excel, that you created. Can you tell me how I can connect the Excel Sheet to Model?
Heiko
Hey Heiko,
there's a node type for excel connection. And some hints in the help file.
Here's my script. You should be able to paste it into the transaction window.
transaction 1 modelChange 'Add baseCS, cs1, lineX' { node User.Objects.baseCS Bentley.GC.NodeTypes.CoordinateSystem { Technique = 'AtModelOrigin'; DGNModelName = 'Design Model'; SymbolSize = 1; } node User.Objects.cs1 Bentley.GC.NodeTypes.CoordinateSystem { Technique = 'ByUniversalTransform'; CoordinateSystem = baseCS; XTranslation = 2; YTranslation = 1; ZTranslation = 1; } } transaction 2 modelChange 'Add excelGridX, excelGridY' { node User.Objects.excelGridX Bentley.GC.NodeTypes.ExcelRange { Technique = 'ReadValue'; WorkbookFileName = 'C:\range1.xlsx'; SheetName = "sheet1"; RangeAddress = "c3:e9"; } node User.Objects.excelGridY Bentley.GC.NodeTypes.ExcelRange { Technique = 'ReadValue'; WorkbookFileName = 'C:\range1.xlsx'; SheetName = "sheet1"; RangeAddress = "h3:j9"; } } transaction 3 modelChange 'Add lenghtY, lenghtX, point1, point2' { node User.Objects.point2 Bentley.GC.NodeTypes.Point { Technique = 'ByCoordinateList'; CoordinateSystem = cs1; XYZTranslation = excelGridY.Value; } node User.Objects.point1 Bentley.GC.NodeTypes.Point { Technique = 'ByCoordinateList'; CoordinateSystem = cs1; XYZTranslation = excelGridX.Value; } node User.Objects.lenghtX Bentley.GC.NodeTypes.Expression { Technique = 'Default'; Value = point1[6].X-cs1.X; } node User.Objects.lenghtY Bentley.GC.NodeTypes.Expression { Technique = 'Default'; Value = point2[6].Y-cs1.Y; } } transaction 4 modelChange 'Add gridX, gridY' { node User.Objects.gridX Bentley.GC.NodeTypes.Line { Technique = 'ByStartPointDirectionLength'; StartPoint = point2; Direction = cs1.XDirection; Length = lenghtX; } node User.Objects.gridY Bentley.GC.NodeTypes.Line { Technique = 'ByStartPointDirectionLength'; StartPoint = point1; Direction = cs1.YDirection; Length = lenghtY; } } transaction 5 modelChange 'Change gridX, gridY, lenghtX, lenghtY' { node User.Objects.gridY Bentley.GC.NodeTypes.Line { Technique = 'ByStartPointDirectionLength'; Length = lenghtY; } node User.Objects.gridX Bentley.GC.NodeTypes.Line { Technique = 'ByStartPointDirectionLength'; Length = lenghtX; } }
and the excel sheet. I placed it just under C:/
range1.xlsx
cheers
thats very cool stuff, thanks for sharing.
I have only two more question about this.
1. Do you know how I can create Points on every Intersection of the Axis, so that I can put columns onto them. Is it possible to intersect geometries with a node?
2. How do i have to write the Code to get the first or the last item of a list? This Option would be great to have, if you consider to design walls on the outter lines of the Grid.
Thanks anyways for your Support. You helped me a lot so far.
