I have list of objects and I have another list of true false.
I wanna make list of all objects are true
like this.
List1:(Curve 1,Curve 2 ,Curve 3 )
Pattern list:(True,False,True)
Expected result: (Curve1,Curve3)
how can I make this function ?
Hi Ehsan,
You can use VBA to do this. You can create a selection list and then select all of them. Then you can go through the properties of each one of them and put the required values for true or false for their Visible property. You can use loops to ease the process.
You can also create interfaces to do this. For example, if you have TXT files for each of the lists, you can use the interface to import the same and then apply these values to the properties.
HTH
Satadal.
no I have to do this in Generative component
Please can you post specialist questions about GC in the GC forum, you will get a quicker response there. This and your other current post should be moved to that forum shortly.
Marc
