I just wonder that is there any option for BuildingContent node output to be SharedCell / Instance rather than a copy of component ?
Because exported file size of BuildingContent node is huge! compared to Cell node which is basically a Shared Cell export. But it require manual assignment of Data and P&F.
Emre.
Hi Emre,
Currently, GenerativeComponents does not support that type of placement. It might be able to do so if the AECOsim Building Designer (user-defined) "Object" provides such a capability. Otherwise, you'd need to construct those entities as simple cells, losing the advantages of compound cells.
In any case, I'll make note of your concern and we will investigate whether there is something we can do to alleviate the situation.
Volker
