Function comments disappearing
Hopefully a very simple question and answer! When I write a function in GC and want to add comments to it (by doing '//<insert comment>'), every time I click "Apply" the comments disappear!
Can anyone help?
Cheers,
Walter
  • Hi Walter,
    GenerativeComponents supports comments in functions, both named functions and anonymous functions (those in nodes' ByFunction( ) techniques).
    GenerativeComponents also supports comments in script transactions.
    Therefore, what you observe is not the expected behavior. In order to help I need more information.
    1. What version of GenerativeComponents do you use?
    2. What are the steps that get you to the Editor dialog (that's where I assume you are clicking the Apply button)?
    3. If you don't mind, could you please attach a screen shot of that Editor dialog's contents before clicking the Apply button?
    Once I have that information I might have an answer, or may need additional information.
         Volker
  • Hi Volker, thanks for replying!
    This must have been some sort of temporary bug, as it now works fine (a day after the problem was occurring), as you say! I can still send you information should you wish, however this issue has been resolved.
    Thanks, and sorry for any wasted time,
    Walter
    Answer Verified By: Walter Thompson
  • Hi Walter,
    That's OK, and you are welcome.
    I am glad to hear that it works as designed. Usually it's difficult to tell retroactively what the cause for some temporary, unexpected software behavior was.
    Best success,
           Volker
