Hello all,
This is quite an open-ended question, but has anyone else noticed/experienced very slow speeds when using GC?
For instance, when changing inputs to a coordinate system or some other minor change, I sometimes have to wait 2+ minutes for the program to catch up! Is this some issue with my hardware, or has anyone else found this an issue?
My models are not particularly complicated, but I have noticed that the problem gets worse as the model increases in complexity, but seemingly much quicker than with other software (e.g. Dynamo).
Walter
Hi Walter,
We are aware of performance problems in GenerativeComponents. We will continue to improve GC's performance. From CONNECT Edition Update 3 to Update 4 we achieved that some scripts run 90% faster (i.e. in Update 4 they need only 10% of the time they needed in Update 3). If we receive specific scripts that exhibit performance deterioration, we will continue to investigate and remedy performance problems.
Volker
Answer Verified By: Walter Thompson
