When placing a Slab node in GC you have the option to parametrically control its thickness using the "Slab_Common_Thickness" input parameter. Is there a way to access this input when doing a slab ByFunction? Presumably if there is, you could also do the same for slab width, or also things like wall height and width etc.
Walter
Hi Walter,
We are looking into this.
Currently it seems the best way to achieve consistent results is by defining the required CatalogItems before they are needed in GC, and using the properties specified in those Catalogitems.
Volker
