Hi all,
Just wondering if there is a neat way to measure the distance between two points along a particular plane / direction? For example instead of measuring the 'true' distance between points; it would be useful to be able to calculate the measurement between them in just the x & y values rather than taking into account the z value.
I found the point node technique "ReportPointPositionInAnotherCoordinateSystem" that does exactly what I am trying to achieve; reporting the xyz offset of a point in relation to the input coordinate system; however it does not seem to support multiple coordinate systems (corresponding to the list of points) which I require for the situation.
Thanks in advance,
Edward
Hi Edward,
First thoughts are if you just wanted to ignore the Z value of a point you could just use an expression with something like {point1.X, point1.Y}. Which would return the x and y of that point. This could then be a list of points etc..
You could then use some maths to measure between points or generate temporary lines and measure the length.
Wayne
Hi Wayne,
Thanks for the quick reply. I did actually end up going back to basics and using trig to resolve each axis; however it is not quite as elegant a solution as I hoped for when calculating relative to a set of custom coordinate systems, where the 'z' direction does not actually align with the baseCS.Zdirection. I had to implement a 'construction' point node to calculate the angle in order to resolve the distance in only the one axis.
Sample code:
transaction 10 modelChange 'Add constructionPt, Zoffset'{ node User.Objects.constructionPt Bentley.GC.NodeTypes.Point { Technique = 'ByCartesianCoordinates'; CoordinateSystem = EBtbmCS[0]; XTranslation = 0; YTranslation = 0; ZTranslation = 3.15; Visibility = NodeVisibility.Hidden; GraphLocation = {1974.129, -283.129}; } node User.Objects.Zoffset Bentley.GC.NodeTypes.Expression { Technique = 'Default'; Value = (Distance(EBtbmCS[0],point3))*(Cos(Angle(EBtbmCS[0],constructionPt, point3))); GraphLocation = {2229.009, -461.529}; }}
Perhaps this could be simplified further by utilising a Dpoint3d rather than creating an additional 'construction' point node? I couldn't figure out how to create this point based relative to the custom CS though, to simplify the operation to just a single expression node.
Ed
