Hello Good GC Community,
So I was doing a design, you know just chillin with some scripting to do a house project, that involved references from other DGN files.
The thing is that the conceptual design file was the one with the GC script, and then it referenced other files to do the final design (files with floors, walls, foundauntion, etc...)
So here are the "Stranger Things", today I woke up early to continue working and opened the Conceptual GC DGN file and nothing appeared, just the references.
And the funny thing is that the script was somehow transmited to one of the referenced files!!
Anyway, I fix this by restoring the file from the cloud services.
Anyone knows what this may have been?
Just to be careful in the future
p.s: I do have a copy of the corrupted file and the one with the tramsited data in case anyone want to find out what happened
Hi Rafael,
Yes, this would be good to investigate. Please send the "after" files and also any "before" versions that you still may have on cloud backup or elsewhere. If you remember the steps that led to this script exchange, please let us know as well. Which ABD version are you using?
Volker
Hello Volker,
Thank you for reply!!!!
I'm using ABD version 10.03.00.40 (Update 3),
Whay I did that I think made the software have a existencial crysis was using GC like ABD, I extracted plans from GC and do Hypermodelling with the plans, also I referenced models from different files....so that could have confused the software, all that exchange.
I'm attaching the files,
"The CPT-M2-Muros - AsBuilt" is the file that the GC script infiltrated on, the others are the GC file before and after.
GC Files.zip
Thank you, Rafael.
I will look at the files tomorrow.
