Hi
I created a script on GC to place objects in series along a polyline.
Until yesterday this script worked great but from today it still keeps giving me the same error.
Can anyone tell me anything about it?
Davide
Hi Davide,
If you hover over the error does it indicate anything specific?
Just at a glance, did you have something connected to Plane1's "Spacing" input but no longer do? What is the value for Spacing?
Hi Steve,
If I hover over the error it says "Internal error "
Entering the knot just asks me two things:
I repeat that the process, until yesterday, worked but now no longer works and I just do not understand why.The workflow is the same loaded on YouTube where you see how to position the railroad sleeper along an OpenRail track
Fastest trouble-shooting is possible if you provide the file that contains the script and the reference file from OpenRail. Otherwise we end up guessing a lot.
If the information is confidential, please send those files directly to Volker.Mueller (at) bentley.com. I'll forward them to Steve.
Thank you,
Volker
Good morning, I am facing pretty similar issue the Internal error. please find script attached.
Hello Lenka,
You can try to give the input of the Curve as Polygon[0], the same when you are creating the points that way it will not be getting the error. That kind of errors signifies that the inputs or the calculation of the node is not working properly.
Regards,Alifur
