Hi Volker,
As the licensing model pushes users inevitably towards CONNECT editions, what are the options for users of vanilla MicroStation (not AECOsim) to have access to a version of GC? ie is there a stand-alone version?
RegardsRobert
Hi Robert,
With CONNECT Edition, GenerativeComponents is available only as companion feature to AECOsim Building Designer. Pragmatic option for MicroStation users who want to continue using GenerativeComponents is to switch to AECOsim Building Designer CONNECT Edition. In CONNECT Edition the workflow selector permits users to focus on those workflows that are relevant to them, e.g. Modeling, Drawing, or Visualization analogous to what they would encounter in MicroStation CONNECT Edition.
Volker
Just to add, the default workflow in GC CONNECT is Computation Design which offers all of the base GC tools.
And as Volker pointed out you can choose any of the other available workflows depending on your needs, which will replace the GC tools in the ribbon bar while the Node Types are always available.
