VBA interface error: failed creating the comp manager - 0x80040583
WSDOT loaded their Resources to my machine so I could use the WSDOT environment but when I started to use the WSDOT "Custom Tools" it did not work and have the ERROR listed above. WSDOT told me to ask this question to Bentley to correct the error. What is your opinion to solve this. Hermi Bella 206-363-1675 bellahermi@yahoo.com
I agree with Volker that you should specify what product and version do you use. This is common rule for any question, because there are many products and many versions. Based on it you should choose a proper forum. Because you mentioned WSDOT, I assume civil forum would be the righ one?
You should be able to move your post yourself, see Move tool in More menu under your post. If you will decide to create a new post (which is not recommended because of duplication of the same questions in different forums), please delete this original one.
I also recommend to search for error ID at first, because it was discussed already and I also found wiki page about this problem.
With regards,
Jan
Just to add to Volker and Jan's comments regarding the need to post in the correct community for the product you are using, and of course searching first, it's also best not to include a phone number or email address within a thread.
