I have 2 separate issues.
(Refer the image below) I am trying to find an intersection point between white vertical lines and the green dotted line. As can be seen in the image below, white vertical lines are projected on green lines. I am expecting a single point at each intersection between white lines and green line, which I am getting apart from a few locations, where I am getting some random points on green lines. Can anyone explain why these points are generated where there is no intersection point there!
(Refer Image Below) I am trying to place a point using Point bydirectionanddistancefromorigin node where I am inputting the distance manually and using Y Direction from a CS. I am getting (red) points correctly at most of the location apart from where the alignment line changing curve. For some reason at few locations, I am getting offset points in a rendom direction even though I have provided Y direction from the corresponding CS. Please note: CS Placement is by spacing along the curve and spacing is coming from an excel sheet.
Please let me know if you need more information.
Jaimin Patel
Hi Jaimin,
Yes, please, we do need more information. Best way for us to reproduce the problems you report is when you kindly send us the scripts that generate what you show in your screenshots. Then we can analyze what is going on and what the cause of the perceived misbehavior is.
As you can see from Sandeep's response, attempting to recreate what's happening from screenshots is a bit of a guessing game with some likelihood that guesses are wrong, meaning that what we guess does not produce the same, seemingly incorrect, results.
So my guess is that in the second screenshot it could be some missed replication causing the offset to deviate from your expectations, for example if the polyline shown is a list of lines, the points' offset directions may pick up only the first of the coordinate system Y directions by corresponding indices based on the polyline instead of the coordinate system.
Volker
Hi Mueller,
I have replied Sandeep and provided all the information files.
For further information and background about the Solids Working Area please refer to Series Index - Setting Up in the Real World.
Marc
