Hi everybody,
Just to add some background, this is my first experience with Generative Components, so I am still trying to figure out the ins and outs of the program. I do have basic programming experience in C++ and Java, so I can sort of understand the scripting language.
I should also point out that I am currently using Generative Components V8i (SELECTseries 6), so it is an older version.
Basically, I am trying to model a sign structure that has multiple variations, so I am trying to use GC to lessen the amount of time spent creating separate models. So far, I have managed to figure out how to create points and draw lines by using simple tutorials and commands.
I ran into trouble when I needed to find a way to create a zigzag effect between points (they are already in a list, in the order they need to connect). I have tried to use the ByChaining, ByLacing, and Polyline ByVertices methods, but nothing has resulted in a success so far. I am still having trouble understanding the scripting, namely the difference between a script transaction and a model change transaction, as well as using functions.
I have attached a screen capture of the code that I am currently having problems with. On it, I have the various methods I have tried to use along with my method to create the point list. The transaction to create the point list is a script transaction btw.
If anyone could offer a solution and/or explain to me the difference/how-to-use the scripting vs model change transactions, it would be much appreciated. I will also attach a screen capture of what I have so far modeling wise.
Shannon
HI Shannon,
I didn't manage to replicate you script, maybe you could save the script out of the editor and so we can see the whole script.
My approach to creating a zigzag poly between points would be to use 2 lists one for the top and one for the bottom.
I then wrote a little function that would allow me to shift the top startpoint along one point and I then did the same on the bottom but setup a skip point to give that "truss" look.
maybe you will find something useful in that. (unfortunately I am using OpenBuildings update 5 so I can't give you the DGN)
The function should work in either version. just setup a point and change it method to byfunction and past in the function.
If you are farmilary with C programing i am sure you will be able to modify to suit from there.
function (Point BottomPts, Point TopPts, int TopShift, int BottomSkip){
Point MyList = {};int b = 0;
for (int i = 0; i < BottomPts.Count; ++i){Point MyPt = {};int t = i + TopShift;
MyPt = new Point().ByCoordinateList(baseCS,BottomPts[i].XYZ);MyList.Add(MyPt);
if (t < TopPts.Count){MyPt = new Point().ByCoordinateList(baseCS,TopPts[t].XYZ);MyList.Add(MyPt);}i = i + BottomSkip;
}return MyList;
I also recorded a quick screen grab of it in action.
Wayne
Hi Wayne,
Thank you so much, your response was very helpful!
It took a while for me to implement it into my program, but after a while it finally worked and the result is perfect.
Again, thanks,
