I've been trying to produce a series of sections within a GC model. Ive been trying to create clip volumes at specific spacings along a curve. Ideally I would like to be able to replicate the clip volumes along the curve so they update automatically if the curve changes.
Is this something anyone else has managed to do?
Mike
Hi Mike,
Sure can.
Just need to place a coordinate system (say byspacingalongcurve) on the BSpline.
I did find I needed to add another coordinate system to rotate the section to the orientation (along the line) but it depends which direction you would like to view.
Not a great description so I have attached a sample DGN.
Wayne
MultiSections.dgn
Thanks Wayne, I was nearly there I think. I wonder if the issues I was having may be from use of 3D BSplineCurve, Ill recreate on single plane and go from there.
Many Thanks
