Hi All,
Over the past few months I have been working with one of our Bentley users, Tapani Talo, modeling a high rise tower using GenerativeComponents and OpenBuildings Designer. Mr. Talo had some very interesting ideas for a tower design and was looking for a way that he could conceptually model the tower without having a defined program or site. He needed a model where he could explore different design ideas, variations and what-if scenarios without endlessly rebuilding the model. A problem tailored made for GenerativeComponents.
He has generously allowed me to share what I learned throughout this process. I have put together a series of YouTube videos showing how I set up the GenerativeComponents model(s). These will be posted on YouTube over the next few weeks. The first in the series is posted today.
Establishing Tower Geometry
For those of you that have taken the GenerativeComponents QuickStart you will recognize many of the same techniques for creating a stacking model that drives the Floor Manager, but you will also see some new concepts like linking one GC model to another in order to use geometry in one model to drive geometry in another model. This turned out to be a very useful technique in working with such a large model.
I hope you enjoy.
Mary Chib
Hi Jeff,
Sorry for the late reply.
That makes sense. I have been working through some workflows with the ImportGCModel and I can see where it is useful but as you say the GNT workflow is better adapted for the approach I was thinking of.
The main reason we were looking for a different approach is we have struggled in a team environment with GNT updates not flowing through once they have been replaced. I thought the ImportedGCModel might simplify this situation.
All good
Wayne
Thanks for the explanation.
Jeff Brown said:a GMIP must be a root node, that is, a node that doesn't have inputs from any other nodes.
Presumably, you mean any other nodes in the 'outer client' or 'source' graph. In Mary's case, the GC_TowerGeom.dgn has a lot of output properties that can be connected to other nodes in the 'importing' or 'client' GC model / graph. Not shown in the vid, but I presume that the input properties will also be available in the client model.
OK. I assume that when you say the GIMP must be a root node, you mean the 'source' graph can not have another GMIP stored separately?
So, if the GC_TowerGeom.dgn provides the base curve for setting out the facades, and the user has another GMIP for the facade panels, this second GMIP could to be imported into the 'client' graph separately and hooked up?
If there are nested 'downstream' GMIP's in the imported node, they could be imported as separate GMIP's in the 'client' model to avoid forcing the user to re-wire the nodes? Once imported, the re-import function would be specific to each GMIP node to keep things as 'root' and replaceable / managable as possible?
Jeff Brown said:it's expected that most nodes in the client model will be connected, either directly or indirectly, to the outputs of the ImportedGCModel, rather than to its inputs.
Not being able to feed inputs into the GMIP is a problem. The inputs presumably can already be exposed as Sliders? It would make sense to have these at Node level and not overload the active model's Control Panel, I think.
Is this the main difference between GMIP and GNT? It would be great to narrow the gap.
Hi Dominic,
Firstly, let's define "source model" as the GC model in which the GC model properties are defined; this could also be called the "core" or "producer" model. And let's define "destination model" as the GC model that contains the ImportedGCModel node; this could also be called the "extension" or "consumer" model.
The terms GMIP (GC model input property) and GMOP (GC model output property) are relevant only in the context of the source model. The destination model doesn't have any GMIPs or GMOPs.
So, then, my statement "a GMIP must be a root node, that is, a node that doesn't have inputs from any other nodes" means within the source model, only. That statement has no bearing on the destination model because, again, the destination model doesn't have GMIPs.
A source model may have any number of GMIPs, as long as each of those GMIPs is a node that doesn't have any inputs (within the source model). In the following small source model, I've indicated the two nodes that could be GMIPs:
And then if I actually designate both of those nodes as GMIPs...
then, in the destination model, both of those nodes will manifest as input ports on the ImportedGCModel node:
The person who works on the destination model can't choose which of the ImportedGCModel's inputs they want to provide; they must provide values for all of them. Just as with any type of node having required inputs, you must provide values for all those inputs before the node can operate.
The types of nodes given to the ImportedGCModel's inputs must match the corresponding types of the GCIP nodes in the source model; for example, CoordinateSystem for CoordinateSystem and Slider for Slider. The popup "tooltip" indicates this for each input port of the ImportedGCModel.
(As you probably know, the Control Panel lets you choose which specific sliders and other controls appear within it.)
Regarding the differences between GNTs and ImportedGCModel nodes, here are the main differences::
I hope I've addressed your questions and concerns. As always, please respond if you want additional information.
Jeff
Thanks for pointing out the GMIP function or step in the process of generating a 'source' GC_*.dgn for use as a ImportedGCModel node in a 'destination' model.
Jeff Brown said:"a GMIP must be a root node, that is, a node that doesn't have inputs from any other nodes" means within the source model, only.
Jeff Brown said:the ImportedGCModel node to designed to appear only once in the destination model, typically near the beginning (left side) of that model. In other words, the destination model uses the source model as a starting point.
As mentioned above, it would be useful to expose the nested IGCM's on import. This would then allow the user to synch the nested IGCM's on demand from the 'destination' model.
Jeff Brown said:A GNT cannot be redefined after its initial creation .The best you can do is delete its definition and then re-create it from scratch.
> Would I be correct in saying that there can only be one GMIP and GMOP in each 'source' model?
No, there can be any number of each. The example I showed in my previous message had two GMIPs in the same source model. Meanwhile, any or all of the nodes in that model could have served as GMOPs.
> So, the user should still be able to daisy chain IGCM nodes in the 'destination' model? User A works on panelising a surface for a facade grid. User B works on a facade panel. User C inserts both GC_A.dgn as an IGCM (which has input/output ports) and GC_B.dgn; and wires the wires the output ports from GC_A.dgn to the input ports in GC_B.dgn. This should still work?
Yes, that should work.
> But designs do not start and end between the left and right side of one model. There needs to be a way of linking / nesting the GC models across multiple files... It seems like we should be able to do this as long as each model has its GMIP and GMOP defined? I assume that the destination file will copy the IGCM script (and any other input) so there is no dynamic 'late binding' stuff necessary?
That should work; IGCMs can be chained/nested. Any destination model that includes an IGCM node may mark that node as a GMOP (along with any other nodes it wants to mark as GMIP/GMOP). Thus, that IGCM will be exposed to each "tier 2" destination model (which, in turn, will include its own IGCM node that's linked to the tier-1 destination model).
The user of a tier-2 destination model is not be able to directly refresh from the original source model, nor should they be allowed to, since such a refresh might disrupt the intervening tier-1 destination model. (Remember that these links are not live; they're simply pulling information from a file that was saved at some previous time.)
> IGCM's work so similarly to GNT's I wonder if there should not be a 're-import as GNT' function. User plays around with graph until its relatively stable... or the project transitions from scheme to detailed design. User converts IGCM to GNT in the destination model. Bear in mind, there will be a lot of different destination / consumer models at the 'periphery'.
That's an interesting idea. I'll add that to the list of requested features. Thanks.
