ExcelRange in a function
Hi All,
Just wondering if someone could help me out with a function where I need to include an ExcelRange so I can loop through different sheets to grab out relevant data.
For example just taking the ExcelRange part, if I wrote a function like this:
function ()
ExcelRange MyExcelData = new ExcelRange().ReadValue("workbook.xlsx","sheet","A1:A5");
return MyExcelData;
(with the correct workbook and sheet etc)
It returns I have an issue with the part new ExcelRange()....
any tips on what I have done wrong?
Wayne
  • HI  Wayne,
    a couple of suggestions
    1. just as a low-level suggestion would it be possible to create an excel range for each sheet, then use a "list" of these ranges as inputs to your function? then write the function.
    2. as a part of the function could you use a series of excel read functions to build an array of data and then execute your function on that array
    Brenden
    Brenden Roche
    Applications Engineer
    Bentley Systems, Manchester UK
    This is a test
  • Hi Brenden,
    I agree with option 1, it will work and I have used it in the past. For this one I have 52 sheets so I was looking for a way to loop through them. They are just floor levels of a building so I have a list of floors so could use that list to loop and match the names of the sheets.
    The second one is where I am stuck.
    I placed a ExcellRange with a read option in a function but it keeps giving me an error. Not sure I have the syntax correct?
    Wayne
Reply
  • Hi Brenden,
    Wayne
