I had Openbuildings Generative Components Update 5 installed and I recently updated to Update 6. I am having a problem with opening the files which were created in Update 5. I noticed that the opening the file is very slow, in fact, it's not even opening at all. Does anyone have any idea about it?
The version I am using is,
Also, I noticed that there is a new version available for update six (10.6.3.4) What is the difference between what I have got and what is available latest?
Jaimin Patel
Hi Jaimim,
The new build released (10.6.3.4) has some essential fixes that were reported in the earlier released build.
Are you facing the slowness while opening existing files only or even for new files? We haven't received any complaints specifically regarding this before. Can you share a file that we can test?
Tathagata
Tathagata Saha Thanks for your responce.
It's not just one file having an issue. All the files that were created previously are not working on Update 6, it takes forever to open, in fact, some files are not even opened at all. I tried those files back on Update 5 and it's working fine. We have installed Update 6 in various machines recently and I tried the same file in the different machine with update 6 and everyone have the same problem.
Please share a sample file with us.
Either here, or maybe you can file a Service Request and share the files through that.
If you have any delivered Bentley workset installed, it may also be worthwhile trying to open a random DGN file from there just for testing purposes.
