Hello, I am trying to generate a surface between a circle and a rectangle.
Please note the both elements are above each other in Z direction.
What would be the best way/ways to do it?
Have you tried using the BSplineSurface FromRailsAndSweptSections?
For the inputs use the circle and rectangle for Section0 and Section1 respectively, and add a line from a rectangle vertex to a point on the circle for 'Rail0'.
May not be the best way, but it seems to work for me...
Hi There are a few ways to achieve this, one suggestion below from Robert is a good one. Another would be to use the LoftCurves method.
you would get something like this.
here is the script in text format so you can give it a try
transaction 1 stateChange 'Add baseCS' { gcModel { node User.Objects.baseCS Bentley.GC.NodeTypes.CoordinateSystem { Technique = 'AtDGNModelOrigin'; DGNModelName = 'Design Model'; SymbolSize = 1; GraphLocation = <auto> {40.0, 40.0, 0.0, 116.37}; } } } transaction 2 stateChange 'Add point1, point2' { gcModel { node User.Objects.point1 Bentley.GC.NodeTypes.Point { Technique = 'ByCartesianCoordinates'; CoordinateSystem = baseCS; XTranslation = 1000; YTranslation = 1000; ZTranslation = <free> 0.0; GraphLocation = <auto> {314.0, 40.0, 0.0, 155.43}; } node User.Objects.point2 Bentley.GC.NodeTypes.Point { Technique = 'ByCartesianCoordinates'; CoordinateSystem = baseCS; XTranslation = 1000; YTranslation = 1000; ZTranslation = 5000; GraphLocation = {322.667, 213.0, 174.0, 155.43}; } } } transaction 3 stateChange 'Add circle1' { gcModel { node User.Objects.circle1 Bentley.GC.NodeTypes.Circle { Technique = 'ByCenterRadius'; CenterPoint = point1; Radius = 500; Support = baseCS.XYPlane; Fill = false; GraphLocation = {1229.4, 125.8, 0.0, 142.41}; } } } transaction 4 stateChange 'Add point3, point4' { gcModel { node User.Objects.point3 Bentley.GC.NodeTypes.Point { Technique = 'ByDirectionAndDistanceFromOrigin'; Origin = point2; Direction = baseCS.XDirection; DistanceFromOrigin = {-1000,1000}; Visibility = NodeVisibility.Hidden; GraphLocation = {528.324, 458.971, 174.0, 155.43}; } node User.Objects.point4 Bentley.GC.NodeTypes.Point { Technique = 'ByDirectionAndDistanceFromOrigin'; Origin = point3; Direction = baseCS.YDirection; DistanceFromOrigin = {-1000,1000}; Replication = ReplicationOption.AllCombinations; GraphLocation = {834.053, 453.544, 0.0, 155.43}; } } } transaction 5 stateChange 'Add polygon1, polygon2' { gcModel { node User.Objects.polygon1 Bentley.GC.NodeTypes.Polygon { Technique = 'ByVertices'; VertexPoints = {point4[0][0], point4[0][1], point4[1][1], point4[1][0]}; PlaneIndex = 1; Key = ''; GraphLocation = {1162.733, 372.866, 0.0, 116.37}; } node User.Objects.polygon2 Bentley.GC.NodeTypes.Polygon { Technique = 'ReversePolygon'; PolygonToReverse = polygon1; AutoHideInputs = true; GraphLocation = {1412.653, 414.344, 0.0, 116.37}; } } } transaction 6 stateChange 'Add bsplineSurface1' { gcModel { node User.Objects.bsplineSurface1 Bentley.GC.NodeTypes.BSplineSurface { Technique = 'LoftCurves'; Curves = {circle1, polygon2}; Order = 2; UCurveDisplay = 4; VCurveDisplay = 4; GraphLocation = {1647.853, 279.944, 0.0, 116.37}; } } }
To use the text file just start a new GC file and open the transactions pane and click on the blue square to edit the transaction list.
With the editor open > File > Insert Text from Text file.
Hope that helps
Wayne
I will give it a try, and some tweaks before I give a feedback.
But I need to ask you, is there a way where I can replace the line between circle and rectangular to a Curve?
Thank you anyways!
Thank you I will try it
For that requirement you would then use Robert's suggestion.
here is the txt
transaction 1 stateChange 'Add baseCS' { gcModel { node User.Objects.baseCS Bentley.GC.NodeTypes.CoordinateSystem { Technique = 'AtDGNModelOrigin'; DGNModelName = 'Design Model'; SymbolSize = 1; GraphLocation = <auto> {40.0, 40.0, 0.0, 116.37}; } } } transaction 2 stateChange 'Add point1, point2' { gcModel { node User.Objects.point1 Bentley.GC.NodeTypes.Point { Technique = 'ByCartesianCoordinates'; CoordinateSystem = baseCS; XTranslation = 1000; YTranslation = 1000; ZTranslation = <free> 0.0; GraphLocation = <auto> {314.0, 40.0, 0.0, 155.43}; } node User.Objects.point2 Bentley.GC.NodeTypes.Point { Technique = 'ByCartesianCoordinates'; CoordinateSystem = baseCS; XTranslation = 1000; YTranslation = 1000; ZTranslation = 5000; GraphLocation = {322.667, 213.0, 0.0, 155.43}; } } } transaction 3 stateChange 'Add circle1' { gcModel { node User.Objects.circle1 Bentley.GC.NodeTypes.Circle { Technique = 'ByCenterRadius'; CenterPoint = point1; Radius = 500; Support = baseCS.XYPlane; Fill = false; GraphLocation = {1229.4, 125.8, 0.0, 142.41}; } } } transaction 4 stateChange 'Add point3, point4' { gcModel { node User.Objects.point3 Bentley.GC.NodeTypes.Point { Technique = 'ByDirectionAndDistanceFromOrigin'; Origin = point2; Direction = baseCS.XDirection; DistanceFromOrigin = {-1000,1000}; Visibility = NodeVisibility.Hidden; GraphLocation = {528.324, 458.971, 0.0, 155.43}; } node User.Objects.point4 Bentley.GC.NodeTypes.Point { Technique = 'ByDirectionAndDistanceFromOrigin'; Origin = point3; Direction = baseCS.YDirection; DistanceFromOrigin = {-1000,1000}; Replication = ReplicationOption.AllCombinations; GraphLocation = {834.053, 453.544, 0.0, 155.43}; } } } transaction 5 stateChange 'Add polygon1, polygon2' { gcModel { node User.Objects.polygon1 Bentley.GC.NodeTypes.Polygon { Technique = 'ByVertices'; VertexPoints = {point4[0][0], point4[0][1], point4[1][1], point4[1][0]}; PlaneIndex = 1; Key = ''; GraphLocation = {1162.733, 372.866}; } node User.Objects.polygon2 Bentley.GC.NodeTypes.Polygon { Technique = 'ReversePolygon'; PolygonToReverse = polygon1; AutoHideInputs = true; GraphLocation = {1412.653, 414.344}; } } } transaction 6 stateChange 'Add point5, point6' { gcModel { node User.Objects.point5 Bentley.GC.NodeTypes.Point { Technique = 'ByCartesianCoordinates'; CoordinateSystem = baseCS; XTranslation = <free> -551.02432737029; YTranslation = <free> 0.0; ZTranslation = <free> 1436.82071285095; GraphLocation = <auto> {862.0, 40.0, 0.0, 155.43}; } node User.Objects.point6 Bentley.GC.NodeTypes.Point { Technique = 'ByCartesianCoordinates'; CoordinateSystem = baseCS; XTranslation = <free> 2949.43572655715; YTranslation = <free> 0.0; ZTranslation = <free> 3419.84125797782; GraphLocation = <auto> {862.0, 235.43, 0.0, 155.43}; } } } transaction 7 stateChange 'Add bsplineCurve1' { gcModel { node User.Objects.bsplineCurve1 Bentley.GC.NodeTypes.BSplineCurve { Technique = 'ByPoints'; Points = {point1, point5, point6, point2}; GraphLocation = {1570.801, 144.658}; } } } transaction 8 stateChange 'Add bsplineSurface1' { gcModel { node User.Objects.bsplineSurface1 Bentley.GC.NodeTypes.BSplineSurface { Technique = 'FromRailsAndSweptSections'; Rail0 = bsplineCurve1; Section0 = circle1; Section1 = polygon2; SkinDirection = DirectionOption.U; KeepSweptSectionsParallelToOrginalSections = true; IfNoRail1RotationAxisFromRail0 = true; IfRail1PresentScaleSectionsByInterRailDistance = true; UniformlyScaleSectionsByInterRailDistance = true; UCurveDisplay = 4; VCurveDisplay = 4; GraphLocation = {1647.853, 279.944}; } } }
