Hi Admin,
In GC how I can make multipe pipe connections as below
Pipe 1: variable dia 800-650 x thickness 40mm
Pipe 2,3,4: Dia355x thickness 32mm
Thank so much
Hi Nguyen,How are these pipe diverging from the main pipe? What are their angles? Can you also share some information on the curvature?
It would be helpful to have few more snaps from different perspectives.
Please see my cad file for position of 4 pipes in space, I define 4 pipe line by layer
NUT GIAO R5.dwg
