when using cells in generative components, is it better to use a .cel file or a .dgn file?
Hello Richard,
It is not known to cause any issue. However we are testing this at our end.
why I ask , is that some cells would come into the model and others would not? these cells were all created from the same file? as you will see the onlt cells that come into the model is a file 3D_U-TROUGH 25M.DGN. ?
while going through the files i can also see all cells that are coming from the file 3D_U-THROUGH.dgn.
yes that's right, but for some reason, not all of them would come into the model when I created separate file cells?
did you find out why certain cells didn't come into the GC model?
