I find having to click on a node's input to see what expression is being used, slow and a bit unpredictable (depending on zoom).
Could a global option be added to change the display of nodes so that expressions are directly exposed on the nodes?
I appreciate this means bigger nodes, but it would be neater than creating supporting expression nodes.
Robert,
By Default we don't have any default settings [At this point we can resize node manually], I will raise one enhancement for future release.
Thanks for raising concern.
Rg,
Sandeep
Answer Verified By: Robert Jones
