Hi All,
Just trying out some of the new features in Update 7.
I might be doing something wrong but I was trying out the operation node and working with a polygon from an array of points.
Then trying to just do some random operations. One question I have is with the order of operations.
So for example if I take the polygons into the Operation node and set it to IsPlanar then flatten all works, but if I flatten first then try to do a IsPlanar it fails?
This might be a bit clearer:
Maybe it is just a different approach to the same outcome.
Anyway just thought I would ask.
Wayne
transaction 1 stateChange 'Add baseCS' { gcModel { node User.Objects.baseCS Bentley.GC.NodeTypes.CoordinateSystem { Technique = 'AtDGNModelOrigin'; DGNModelName = 'Design Model'; SymbolSize = 1.0; GCModelPropertyDirection = PropertyDirection.None; GraphLocation = {42.667, 40.0}; } } } transaction 2 stateChange 'Add point1' { gcModel { node User.Objects.point1 Bentley.GC.NodeTypes.Point { Technique = 'ByCartesianCoordinates'; CoordinateSystem = baseCS; XTranslation = Series(0,10000,1000); YTranslation = Series(0,10000,2000); ZTranslation = 0; Replication = ReplicationOption.AllCombinations; GraphLocation = {330.787, 26.142, 0.0, 156.43}; } } } transaction 3 stateChange 'Add polygon2' { gcModel { node User.Objects.polygon2 Bentley.GC.NodeTypes.Polygon { Technique = 'ByPointGrid'; Points = point1; FacetOption = FacetOption.Quads; PlaneIndex = 1; UClosed = false; VClosed = false; GraphLocation = {589.13, 88.774, 0.0, 117.37}; } } } transaction 4 stateChange 'Add operation1, operation2, operation3, operation4' { gcModel { node User.Objects.operation1 Bentley.GC.NodeTypes.Operation { Technique = 'Default'; Subject = polygon2; OperatorKey = 'CurveGeometry.IsPlanar'; GraphLocation = {868.269, 219.342, 174.0, 125.83}; } node User.Objects.operation3 Bentley.GC.NodeTypes.Operation { Technique = 'Default'; Subject = polygon2.Flatten(); OperatorKey = 'object[].Flatten'; GraphLocation = {866.139, 63.525, 0.0, 125.83}; } node User.Objects.operation4 Bentley.GC.NodeTypes.Operation { Technique = 'Default'; Subject = operation3; OperatorKey = 'CurveGeometry.IsPlanar'; GraphLocation = {1094.694, 50.858, 0.0, 138.608}; } node User.Objects.operation2 Bentley.GC.NodeTypes.Operation { Technique = 'Default'; Subject = operation1; OperatorKey = 'object[].Flatten'; GraphLocation = {1102.002, 217.075, 0.0, 125.83}; } } } transaction 5 stateChange 'Add value3' { gcModel { node User.Objects.value3 Bentley.GC.NodeTypes.Value { Technique = 'Default'; Value = polygon2.Flatten(); GraphLocation = {862.26, -82.913, 0.0, 123.83}; } } } transaction 6 stateChange 'Add value4' { gcModel { node User.Objects.value4 Bentley.GC.NodeTypes.Value { Technique = 'Default'; Value = value3.Value.IsPlanar; GraphLocation = {1097.022, -82.521, 0.0, 123.83}; } } }
Hello Wayne,
I am also seeing the same behavior at my side. It is already informed to our development team. I will let you know if I have more information on this.
