GC Tween Node?
Rhino has this cool tool called TweenCurve and TweenSurface
Is there a quick way to replicate this tweening functionality for parameters?
1. Mstn Parametric Solid Extrusion A. Length parameter= 1.0m, located at say 0,0,0.
2. Mstn Parametric Solid Extrusion B. Length parameter= 5.0m, , located at say 15,15,0.
3. Drop GC Tween Node in Symbolic View. Select Mstn Solid A and B.
4. Select Parametric Solid parameter to tween. Enter Number of tweens. Default: Tween node calculates x,y,z distance between the two selected elements.
5. User confirms. Tween node does the tweening. Edit: the tween'd solids' extrusion lengths would interpolate between 1.0m and 5.0m, and the new solids be located between A & B with equal spacings as a default.
6. User uses Move command to move Solid A. Tween node updates the tweened elements.
7. User uses Move command to move Solid B. Tween node updates the tweened elements.
