I am trying to drive the level name of my solids by a list.
I have a list from excel that contains the name of the elements that I am trying to place.
I can't paste the examples but in generic terms the list would look something like this (level1, level2, level3) etc.
I have used the following within the "LevelName" input: Name.Value.ToString()
"Name" is the list of names
As you can see it is not reporting any errors but when I select the solid it just tells me that it is placed on Level Default
When I hover over the LevelName on the output of "solid1" it lists the level names as I would expect t see them.
I am sure I am doing something wrong but not sure what. Any help would be appreciated.
Cheers,
Alex
I've got a similar problem. I've created 19 solids, and I want to segregate them for two different levels. I prepared a list with 19 string items (with two type of levels name) and I tried to connect nodes but it doesn't work. What is wrong?This node works only when I've got only one string item as an input?
