Using Generative Components, how do i use a Text Node to extrude a 3D Solid from.
I can do it using Microstation Solid tools, and have recorded a macro to do this, but still requires my input.
How can i do this with the nodes and functions in GC
I'm using GC inside OpenRoads 2020.3 (10.09)
Hi Chris,
Happy New Year!
Ideally, this can be done using a Text Node>TextDrop technique of Bspline node>OffsetFromSurface technique of Solid node. But it seems like the TextDrop technique is not working for some reason in my build(OBD U7). I have already reported this to our development team. But you may try this workflow in your build.
Hi Chris & Anik,
Looks like it is the same in OBD U6.
Error talks about text style issue.
Tried just using a function but it had an error as well.
Wayne
Thanks for testing in U6.
A defect has been added for this issue.
Thanks for testing and reporting both. I had tried that method and I get the same issue in ORD 2020.3
Chris
AECOM Roads UK&I Digital Engineering, Design & Solutions Lead | Sector Information Management Lead
Associate Director – Digital
OpenRoads Designer 10.12 | MicroStation 2023 | ProjectWise CE 10.3.4 | ContextCapture | ProjectWise PowerShell 2023 | ProjectWise WSG API | Generative Components | OpenBridge Designer 10.12
Civil 3D 2023 | Dynamo | Navisworks Manage
PowerShell | Visual Studio | Office 365 | Power Platform | Teams | SharePoint | Visio
Speckle | BIMVision | Revizto | Solibri
