Does anyone know what this means? I something doesn't work I usually get some sort of explanation why? but this time I just get this message??
Hi Richard,
My understanding, we get this message when something is mathematically not possible to build based on the given input values(even though they are of right types) .Changing input or giving different input values sometimes may resolve the issue.
Can please share the case where you are finding this issue?
Anik
I am using solid / sweep profile along path. the paths are bsplines and have used it many times by just copying the node and changing the path name. then on the eighth copy i get technique failed and no explanation?
The bsplines I am using for the paths have been created from another bspline that has been projected onto a surface. Up until now without any problems?
Maybe the path has a tiny little corner that the profile can't sweep around which could be removed by creating a new curve from the existing with some tolerance to remove path anomalies. Its hard to tell without seeing the path and profile.
