How to generate the penetrations (in 3D solid) against the MEP services using Generative components? Please watch the video for more details and refer to the attached file.Penetration (2).dgn
Hello Santosh,
we yet do not have any options for creating opening in solid. we only have a penetration option available for walls only.
Regards,Alifur
Do you say that even there are no possibilities with Generative components to create the several openings (for several locations) in 3D solid automatically?
Hi Santhosh,
I think Alifur was thinking in terms of OpenBuildings "openings".
GC definitely has tools for cutting and performing boolean operations with solids.
Here are a few in the methods list.
Maybe there is a way to integrate this with the MEP data to automatically create the shapes/solids for cutting.
Hope that helps
Wayne
Hello Wayne,
Yes, i was thinking about the Opening that we have in our OpenBuildings. The solid cut option can be used but one thing we need to think about is how we can hook the MEP elements as an input in GC and then get a profile of the element and then do that cut operation.
