I am finding that if I use a node for reference files and do a rebuild in my transactions I get an error? and that I have to use the normal reference manager.?
Hello Richard,
Strange because i have a file where i have used the reference attachment node, have tried to use the rebuild transactions many time but i am not seeing anything like this. One question i would ask is whether you have the reference file and the file you are working with is in same folder or in different folder? Because i have tried keeping the file in both same folder and different folder and i am not seeing any issue like that.
Can you please tell me which version of GC you are using?
Regards,Alifur
the reference file and model are in the same folder in PW. The G.C. version I am using is update 6 10.06.03.04
I have not checked this item with PW, but i think i will give it a go and try to check.
