Hi All,
I would like to know if this is possible or has anyone has already done this.
Can I create multiple section/clip volume which is not perpendicular to a curve but rather sits on the alignment itself, like multiple single lines that makes up a curve. Then automatically attach all of the section callouts in proper arrangement on a single model to form an Elevation view i.e of a bridge?
Here's how it should look like (snapshot above), creating an elevation view on a curved alignment is really hard because we can only use clip volumes/section callouts as straight lines although OpenBridge Modeler have the capacity to do a cut along an alignment, it does not have the option to give it a depth so i think this one can be a workaround.
I'm using GC for OBMCheers,
Cris
Hello Cris,
Are you trying to get something like this? Also you mentioned about the feature of OBM to have the to cut through alignment, can you please share a video of that. So that we can place that to our development team.
Regards,Alifur
Hi Alifur,The screenshot is not quite clear, what i'm trying to achieve is a profile view of a bridge along a curved alignment.Here's a video of how OBM cuts through an alignment, we can change the offset of the cut but i think it would be better if we can have the cut through the alignment and then add a forward/back depth to it instead of getting an offset, can we replicate this on GC and have better control?
Cheers,
