Good to see GC getting integrated into OpenRoads/Rail etc. Curious about the version mentioned. Any new stuff?
Dominic,
V10.16.00.80 is a MicroStation Update 16 release version on which ORD 2021 R1 is based on. In this version Parametric cell node is introduced which will help to place parametric cells with the benefit of local variables available to modify cell's parameters. Also one can easily use different variations of cells using this node.
HTH,
Best Regards,
Sandeep
Awesome! Any documentation?
Hi Sandeep, Any Alignment or Terrain nodes for the Civil version?
Dominic, GC is releasing as a companion feature with OBD, help topics for new introduced nodes will be incorporated with OBD help for U9 release. So documentation for new node is not available with ORD build.
Edward, As per my knowledge Civil related nodes are not available with this release.
