[GenerativeComponents C#] How do you create a PointNode as GCOut parameter?
I am using GenerativeComponents Update 8 (10.08.00.40).
I am trying to build upon the C# Sample Solution to create a Generative Component in C# which produces a PointNode as an output parameter but I am having no success and I cannot locate the SDK documentation for the GC Object Model. Please see a simple conceptual example for a generative component which takes two points and a coordinate system as inputs, and should provide a point node as an output that can be used for other purposes.
public class MidpointTestNode : ElementBasedNode
        [GCDefaultTechnique]
        public NodeUpdateResult Default
            NodeUpdateContext updateContext,
            [GCDgnModelProvider] CoordinateSystemNode InputCoordSystem,
            IPointNode StartPoint,
            IPointNode EndPoint,
            [GCOut] ref PointNode MidPoint
            // check inputs for validity
            if (StartPoint == EndPoint)
                return new NodeUpdateResult.TechniqueInvalidArguments(nameof(StartPoint), nameof(EndPoint));
            DPoint3d startPt = StartPoint.GetDPoint3d();
            DPoint3d endPt   = EndPoint.GetDPoint3d();
            DPoint3d uorStartPt = NativeDgnTools.FromMUToUOR(startPt);
            DPoint3d uorEndPt   = NativeDgnTools.FromMUToUOR(endPt);
            // get the midpoint of the two input points
            DPoint3d midPt = 0.5 * (uorStartPt + uorEndPt);
            // create the midpoint node as an output
            MidPoint = new PointNode();
            MidPoint.FromDPoint3d(midPt); // <-- this generates a NullReferenceException
            return NodeUpdateResult.Success;
I am guessing that I am supposed to use one of the static methods like PointNode.CreatePointNode() or PointNode.CreateConstituentNode() but without the SDK documentation or any sample code to adapt, I am not sure how to use them.
Can someone provide an example of how to return a Point node as an output parameter?
Trevor
  • Hi Trevor,
    A node technique method (such as 'Default') is intended to manage only the node's internal state. It's highly unusual for a technique method to create a new Node instance for the sole purpose of handing it off and otherwise forgetting about it.
    Please try this:
    1. Remove the parameter 'MidPoint' from your method's parameter list:
            [GCOut] ref PointNode MidPoint   // Remove
    2. Replace these two statements:
        with this one:
            CreateConstituentNode<PointNode>(this, "MidPoint", addToParent:true).FromDPoint3d(midPt);
    From the user's point of view, there's no difference between an output parameter and a named constituent node.
    HTH
    Jeff
    Answer Verified By: Trevor Watling
  • Ah thank you Jeff. That is in fact what I was trying to achieve. I need "output" nodes from various generative components to be inputs for other nodes.
    Much appreciated.
Reply Children
