I am trying to use GC in ORD. I managed to reference the alignment and to import it as a "Polyline" and I want to project it onto a plane to be able to access chainage values. I have inserted a "Curve" node with the "ProjectCurveOntoPlane" technique, selected the "Polyline" from previous step and "baseCS.XYPlane", however, it throws the stop prohibition sigh with "Check Alignment of Curve" comment.
I have tried with alignment and with a polyline generated from alignment with 0 (nil) offset and no transitions.
I am using ORD 2021 R1(bis).
Any help much appreciated. Thank you in advance.
Val.
Solved using the technique a few posts below. https://communities.bentley.com/products/products_generativecomponents/f/generativecomponents---forum/214015/curve-projectcurveontoplane-error
Thank you guys.
Answer Verified By: Anik Mal
Good to know that it got resolved
