How to subtract solid with solid?
I want to subtract the while solid (solidConcrete) using red solid (solidTunnel)
Hello Kang,
In the solid node, there is a technique called Boolean Operation, where you need to provide 2 solids and there are three operation that can be done, Union, Intersection & Difference. I hope this helps with your query.
Regards,Alifur
Answer Verified By: Kang Teng Teng
