Hello all,
Is it possible to place a particular type of cell along the curve if the radius of curve is less than or greater than some value ?
Thanks in advance
Hello Nikhil,
Nikhil Jose said: radius of curve is less than or greater than some value ?
Can you please explain what do you meant by this? I do not think we have any exceptions for this. If you can send an example dgn file then it would be best.
Regards,Alifur
Hello Alifur
The .dgn contains a line string with multiple curves & different radius so I want to place guard rail if the radius of curve is less that 500m.
Regards.l,
Nikhil
Hi Nikhil
Apologies for the late pick up here. Here is an example of using Conditional Formatting for showing the Visibility of elements based on the radius of an Arc and for fun changing the colour. For guard rail your may want to look at Generated Node Types for treating it like a parametric cell, but the same node visibility conditional formatting would apply.
If the less than value was 10000mm for the arc radius, the syntax in you Visibility property of the node you want to show or hide would be: arc1.Radius > 10000 ? NodeVisibility.Hidden : NodeVisibility.Visible
Stuart
ConditionalFormatting.dgn
