Hi All,
Has anyone had any luck using the ParametricCell node in GC?
When I attempt it, I get the following error:
As yet, there is no documentation on this node, so I am not sure I am using it correctly.
GC2.dgn Culverts.cel
Any help would be much appreciated
Hello Liam,
Thank you for raising the query. Which software you are using to create the Parametric cell? The proper working parametric cell will be out with OpenBuildings Designer update 9 which will release in Q1,2021. Once that will be released then subsequently other Open applications will get the same Parametric cell node.
Regards,Alifur
Hi Alifur,
I have tried this in both the OpenRoads and OpenRail 10.10 releases. I also have OpenBuildings but that does not yet contain the ParametricCell node.
Liam
Yes the Parametric cell node that is present in OpenRoads, OpenRail, OpenBridge & OpenSite would have the parametric cell that does not work properly, As OBD dev team is in development of the Parametric cell node as once the new update of OBD releases then the proper parametric cell will be found in the other stated products.
