How to make pıer cap beam and beam support and vıaducuk slap?but vıaduck % 2 % 7 slope cross sectıon , Legent sectıon slope max %12 and viaduck curve.Pıle,Pıle CAp, Pıe,Pıe Cap, Beam Support, Slap all brıdge sytem
HOW TOMAKE.WE NEED VİDEO.
OBD_GC Make
Prostructures Make
Hello ERKAN,
I am thinking you will be more easy to create the pier if you will using OpenBridge Modeler.
But Please take a look at attached file. and you enable to understand how to create the coping with the slopes.
And let me know if you have further questions.
Thanks.
https://communities.bentley.com/cfs-file/__key/communityserver-discussions-components-files/360/Slopped-Cap-Modeling.gct
How Cut Pıer WİTH SLOPE Angle
Please generate two solids for the slopped coping.
Solid1 will be generated by the node of SurfaceCapping.
Solid2 should generate by the node of ClosedListOfSurface.
Also, the column needs regenerate using the node of SurfaceCapping. becase top of column will be changed due to slope angles.
