Good Day. I am new in Generative Components. I am creating a script, and have some problems with the coordinate system on a curve. I have sied that GC builds Cs creates and another way in line and
in an arc. Who knows how to create points along the curve in one way? This is my code
Hello Anton,
It is not always required to create coordinates to place points, You can place points directly on a curve using the point node. Please have a look at the youtube video for your query. I hope this helps you with your query.
Regards,Alifur
Answer Verified By: Anton Shupeniuk
You have a few options:
Hi Alifur
Thank you for your advice, I have seen this video and added to code a new changes, and what I have
I have creted first point and than coordinate system.
Thank you four advice, everything works fine)
