HI Alifur,
Great Coffee Corner last week.
You mentioned that GC does not support Item Types.
Are there any plans to support this? I know you mentioned using DataGroups but this is only available for OBD.
DataGroups also do not support Expressions and is quite limited functionality-wise. It seems like a lot of new developments will be done at platform level using Item Types, which duplicates a lot of the DGS functions..and would be easier for other verticals like OpenRoads, OpenBridge etc to adopt and share info.
Dominic. Check out Edward Ashbolt's GitHub repository called GCcommunity it included an Item Types node
Chris
AECOM Roads UK&I Digital Engineering, Design & Solutions Lead | Sector Information Management Lead
Associate Director – Digital
OpenRoads Designer 10.12 | MicroStation 2023 | ProjectWise CE 10.3.4 | ContextCapture | ProjectWise PowerShell 2023 | ProjectWise WSG API | Generative Components | OpenBridge Designer 10.12
Civil 3D 2023 | Dynamo | Navisworks Manage
PowerShell | Visual Studio | Office 365 | Power Platform | Teams | SharePoint | Visio
Speckle | BIMVision | Revizto | Solibri
Answer Verified By: dominic SEAH
Thanks Chris. I have been a bit slack in keeping my repo updated, but let me know if you would like a revised version with improvements made and support for update 8.Cheers,Ed
Hi Ed. No worries. Been looking at the repo today. I was looking at ORD specific ones, Terrain, Alignment, Corridor no where near ready for testing
Oh I forgot you were working on those! I did build some alignment and terrain methods recently... One for draping elements to terrain models, and one for placing points / coordinate systems along an alignment. Works fine but requires one of the Civil suite applications, I couldn't get the required assemblies to execute properly within OpenBuildings.
Definitely be interested in seeing what you have managed to develop, might just given me the missing bits I need.
