Good Afternoon,
I have an issue when attempting to cut a profile out of a solid. I cut a profile out of the solid to a specified depth and direction using the "Blind" cut method. However, the depth of this cut is returned incorrectly, often several times larger than the specified variable value. Is this a glitch or am I approaching cutting in the incorrect way?
By coincidence, I've noticed that the returned depth of cut varies with the maximum dimension of the solid being cut. Roughly given by: Returned Depth = 0.0011 * [Specified Cut Depth] * Max([Height], [Width], [Length])
I have attached an example .dgn file which demonstrates the issue.
BoxUnit_vError.dgn
Hi Alex
I just had a quick look and I certainly see what you are seeing. Let me look into it a bit further.
Stuart
I think you have stumbled across something a little odd. We will need to look at it further.
If you require a workaround, you could use the BooleanOperation method.
I noticed when opening your file you aren't on the latest version, so you may have trouble opening the example unless you upgrade.
Stuart.
2705.BoxUnit_vError.dgn
