Hi all,
I'm trying to do a LoftCurve command. I placed a cell along the coordinate system (BySpacingAlongCurve) i created and then created a curve (FromElementsInCell), it worked as i intended but when i try to use the BSplineSurface LoftCurves command using those curves, i get an error. I tried changing the loft order but its still not working.Is there something wrong with what i'm doing? i don't want to use the SweepCrossSectionAlongPath as the profile will not be always horizontal to the alignment.
The cell i placed where the curve is created is just a rectangular profile with a slope at the top
Hello Crisano,
Can you please share the cell file with us so that we can test the same thing on my end.
Regards,Alifur
Footing.celHI Alifur,Here's the .cel file. Btw i'm using the latest generative components version from OBD.Cheers,
Cris
Hello Cris,
In the bsplineSurfaces node, for the curves input try to use curve2.Flatten(). I did the same on my end & got an result. I hope this helps you.
Answer Verified By: Crisanto Aquino
Thanks Alifur, it did work on my end.
Cheers,
