Hi All,
How do we use the Solid (Cut) node? I'm stuck at CuttingSweepDirectionForwards, what is the proper input for this?Regards,
Cris
Hello Cris,
We have noticed the same issue with the CuttingSweepDirectionForwards, putting baseCS.XDirection or the XYplane is giving as Internal error, which should not be the case.
Where as if we try to do the same thing V8i, it is working perfectly. I think we need to file that as an defect. Can you please file an SR for this.
Regards,Alifur
Thanks Alifur, i will file an SR.
Anyway, is there a workaround for this? if i want to cut a solid and split it into many parts.Thanks,
You can try to create another solid and try doing boolean operation to get desired solid results.
Hi Mandal , i facing same issue when cutting a solid by CUT Option, Is they resolve or any updating happen in that Node
Hello K.V,
Sadly it has not been yet resolved. For now i will suggest to use the boolean operation for this purpose.
