How to create point/coordinate system nods on multiple features?
I have a polyline that is selected from elements in range (using level).
When placing points/co-ordinate systems it only recognizes the first poly line segment.
You can see below that the co-ord system ends, when the range contains a longer element.
My models are likely to have various different sections of elements, so I would like to place my points on the entire range.
I presume the "By spacing along curve" coordinate system ends when the first polyline element ends.
What is the approach to place co-ordinate nodes along all polylines (filterbylevelname) in the model?
FULL ELEMENT RANGE SHOWN BELOW (POLYLINE via Level)
POINTS/CO-ORDS ONLY PICK UP FIRST CURVE
